problems to open .max file from HVTFA
Hi Marc, the max file generated by HVTFA is impossible to open with max2curve of versions after 2.9 (chrash) and also by gpviewmax (parsing error) and gpdcreport which opens the page but fails to generate the PDF correctly. It can therefore only be opened with the max2curve of the versions before 2018.
Do you think there could be an fixed in the next 3.4 version and when you think RayDec will be activated too?
Greetings
Re: problems to open .max file from HVTFA
I'm check. I'll introduce these kind of .max files into gphistogram soon (for 3.4.1?), in order to get rid of max2curve.
Raydec or an improved version will be soon added. There is already a preliminary version mixed with the FK module but it is still experimental. Once stabilized, it will moved to a more user-friendly format.
