Simultaneous inversion of dispersion and attenuation curves
javiermt
Post by javiermt »
First, I want to thank you for your work in developing geopsy. It is certainly a valuable tool. I always use the FK and Spac module.
I am currently researching on simultaneous inversion of dispersion and attenuation curves of Rayleigh waves. (Lai 1998; Foti, 2000).
Does Geopsy have any tools for this? Is it possible to use dinver code in matlab, R, or another software to make this joint inversion?
Thanks for your help.
Javier
Re: Simultaneous inversion of dispersion and attenuation curves
Hi Javier,
Attenuation is currently not yet available and there is no active project in that direction. But it should be initiated soon or later.
There is a dinver plugin to start a Matlab script for solving the forward problem. It is not compiled for Windows because of license problems. Under Linux you are free to compile it and link it to you Matlab libraries.
