range of slowness(or velocity) to display
seguuu91
Post by seguuu91 »
Dear,
I have a question with the slowness(or velocity) range to display on gphistogram.
To find out the velocity over 4,000m/s, what kind of parameters should I control?
I'm using Geopsy pack 3.2.2
YJ.Jeon
Re: range of slowness(or velocity) to display
Maximum velocity must be adjusted also while processing FK in geopsy or geopsy-fk (parameter MAX_V).
If there are velocities up to 4000 m/s in the max file, they will be shown in gphistogram. You can also adjust the value range with options of gphistogram -y-min and -y-max (in slowness)
I'm unsure if it is available with 3.2.2, but certainly with 3.3.1 and above.
