Cut curve in max2curve
eshabani
Post by eshabani »
How can I load a curve in dinver that I cut in MAX2CURVE? the cut file that is saved in MAX2CURVE is a max curve but in dinver only target files can be loaded !
thanks
In max2curve graphical interface, there are are two options to save your work: "Save" button at the bottom of the dialog box (right of "Filter") and another "Save" button in the frame dedicated to the current curve ("Save", "Remove", "Log").
The first one is probably the one you used, it saves the full histogram including the selection of samples you performed in the "Grid Statistics" window. It is another .max curve.
The second one, just save the current curve to an ASCII file (4 columns, frequency, slowness, error, weight). This is the format to input in Dinver.
