A values with geopsy
corine
Post by corine »
Good morning Marc,
I haven't find an automatic way to have the value of the peak value (amplification) associated with the frequency. The file that can be saved shows only, if I am not wrong, the frequency values.
Is there a way to also have an automatic extraction ? For the moment, I am just using the tool provided to look on the display, but that is not very precise.
Thanks in advance
Corine
Hi Corine,
Correct me if I misunderstood your question. Do you want to extract the H/V amplitude at the peak frequency? In the saved file, you can extract the amplitude at the peak frequency.
# GEOPSY output version 1.1
# Number of windows = 8
# f0 from average       2.07265
# Number of windows for f0 = 8
# f0 from windows       2.05321 1.9398  2.16663
# Frequency     Average Min       Max
0.01            1.82063 0.480536  6.89794
0.0108984       1.82464 0.47767   6.96989
0.0118775       1.82822 0.474326  7.04659
0.0129446       1.83116 0.470404  7.12825
Run this script (edit file name or modify script interface):
#!/bin/bash
FILE=S10A.hv
FREQUENCY=$(grep "f0 from windows" $FILE | awk '{print $5}')
gpcurve -value $FREQUENCY $FILE
Which gives as output:
2.0532099999999999795 9.5992748074446918594 8.1223796780990280553 11.348137726793865454
Keep in mind that H/V amplitude is not a straight forward proxy to real amplification...
