neutralize a trace
erey
neutralize a trace
Post by erey »
Before calculating a dispersion curve, is it possible to neutralize a single signal in a shot record (which shows an inversion of polarity or noise for example) ?
You should move all signals to a table. There, you can select all signal except the wrong one (play with SHIFT and CTRL). Transfer selected signals to a new graphic and start linearfk again.
