SPAC processing-inversion
pumar
Post by pumar »
Geopsy team,
I need help about SPAC module inversion. I have selected the picking curves and save (spac2disp), but the file saved is *.target format, then i need *.disp file to invert. How can i save to this *.disp file?, is not clear for me the step between save the pick in spac2disp and load the *.disp file in dinver module.
Thanks in advance for your help.
Regards
Jorge
Re: SPAC processing-inversion
In spac2disp, you can select autocorr curves to be inverted directly in dinver (see Wathelet et al. 2005 in BSSA). Another technique is to manually pick the dispersion curve from the dispersion plot (right click, then pick). Save the curve from the Edit menu.
pumar
Post by pumar »
Thank You! its done...
